Hi looking for some advise on tramming.
Getting weird patern when milling in x axis
what tool are you using? looks big (flycutter?) unless i’m mistaken
Sorry using bushmachinetools tripple insert 1”.
And its an xxl with beaver hdz and steel belts
What you are seeing is that the right side of the table is higher than the left.
I usually do this with a peice of mdf…it’s cheap and takes a few passes.
The “step” in the middle could be be a few things, probably “gunk” on the rail, maybe in the V of the wheel.
