Pausing the program
I just recently got my 5 pro and noticed that unlike my XXL, when I pause the program the Z does not come up. It stays in its current position. Is there a setting that i need to change? This is helpful if the dust boot gets clogged or I need to check something.
Thanks
Dan
The lift on pause on the older machines is implemented in Grbl.
On the Shapeoko 5 Pro it was removed in favour of dual Y-axis homing.
Help me understand. How does having the dual Y-axis effect the retraction of the Z-Axis during pause.
We had limited memory, so we chose the dual-Y homing.
I know this was discussed extensively on another thread, but can you explain how the Pause button works on your 5 Pro? I have older model (regular Pro) and when I hit Pause, three things happen. a. Gantry stops moving, b. Spindle stops rotation, c. Spindle rises to safe height.
What happens when you hit Pause?
Just about the only time I use the pause button is when I forget to put the Sweepy on. I am glad my z axis lifts up.
The way its been explained here, on the 5/5.1 Pause acts like Feed Hold seen on other machines. When I press Pause it stops the movement of the spindle almost instantly where it is without retracting. The motor continues spinning. I’ve seen it explained elsewhere that feed hold shouldn’t simultaneously stop the spindle spinning because it could damage the tool or material.
I have really struggled with the proper procedure when needing to pause/stop a run in the middle of a cut. I have a S5 Pro with a spindle. The other day I was about half way through a project when I received a call that required me to leave the house. I hit pause, but as noted, the machine stops moving, but the spindle keeps spinning. I ultimately just hit the stop button in CM which did stop the spindle but it did not raise back up out of the wood so I just shut everything down. When I returned, I turned everything back on and held my breath when I hit the initialize button hoping it would raise up at that point, which it did, but I was not sure of what to expect. Fortunately, I was able to disable one of the toolpaths and just start it back at the toolpath it was in the middle of and let it cut air for about 20 minutes.
So that is a long-winded explanation to say…I am not 100% sure what is the best practice for pausing and restarting in the middle of a project. Could someone please give me a step by step explanation of a pause and/or stop and then how to safely resume without messing things up. If it matters, I am running CM 667. I also have a jog pendant if there is something on there that is better suited for pausing/stoping/resuming etc.
Thanks
Thank you Rob. I understand that.
Everythink just stops exept for the router. I have to turn that off manually. I haven’t upgraded to the spindle yet (xmas maybe). When I’m ready to resume then I just turn the router on an hit start.
Yes, same here. Very happy mine retracts.
