No additional electronics needed. You only need a momentary, NO (Normally Open) pushbutton and a way to connect to the molex pins on the controller board.
Thx, I’ll give it a try then
If you do, you may want to check that thread, that has waaaay more details than needed, but hopefully makes it clear what the feedhold (pause) signal does if you wire it to a pushbutton
