I dont use a bit zero, i have a bit setter. My Z is zeroed off the top of the work piece .
In that case, in addition to the file, let us know step-by-step:
- how you are securing your stock
- how you are setting zero relative to your stock
- what, if any technique you are using to verify zero
- how you are managing all tool changes
and send a photo showing an attempt at cutting in place on the machine.
I found my problem. I rapid to my x,y, z+6mm i confirmed by eye the bit was 6mm above my workpiece, but my glasses screwed up my calibrated eye. The z was .125β lower than i thought.
What caused it to be that far off?
What βKβ is doing ( checking rapped x y z+6) is good practice. I like that. I have manually set the zero points and scene I get lost on more than one occasion. Always stand ready with my finger on the power button when it first starts to cut. Carbide motion shows the precut path it might show up here when itβs off.
When it happens, since I just killed the power it goes back to the back right corner and resets the reference point so I just load everything again and reset the Z probe depth in rapid check the XY plus Z that is usually fix my problem
Oh man, you had to ask .
Well, there are 2 programs required on my project. A front and a back with a thickness change.
I machined the front, then changed the z by .125β to machine the back, but I needed to make a change to some width dimensions.
I started over with a new piece, βverifiedβ the Z zero by eye (forgetting it had been changed for the back of the previous piece).
I appreciate the input here as I learned a LOT!
