Placing a circle tangent to two other circles
as requested on support…
Can I make the selected circle align with the adjacent circles simultaneously?
where a quick re-draw looks something like:
Select and duplicate each of the circles in place:
Then select each duplicate in turn:
n
and add the radius of the circle which one wants to align against the twain:
Select the two new circles:
and apply a Boolean operation which will net us a point at the desired centerpoint:
OK
Select the errant circle:
and grab it by the center:
and drag it into alignment:
Just a question from an old engineering guy. If you know the radius of the three circles. Couldn’t you draw two more circles with the radius A+B and a second with the radius of A+C. Then in theory you could place circle B and C center points anywhere on those circles and be tangent to the large circle?
Keith
Yes, that would work — except the solicitation was to place the large circle tangent to the two smaller circles which were presumably in the desired position.
Well I should have read that closer. :roll_eyes: Too bad they are not running AutoCAD there is a feature to draw a circle called TTR standing for Tangent, Tangent, Radius which would make this process very easy. But then again if a frog had wings he wouldn’t bump his butt.
Given that this is the first time this request has come in, I don’t know that we could justify that interface complexity.
I had to make @keithhoward55 image clearer to my eyes.
