Want to place eight holes of 4.2-millimeter diameter inside the space defined by the two circles…all evenly spaced between the lines and at equal radial angles.
There are two ways to do this:
- place one circle, duplicate it eight times, and rotate each in place by the appropriate number of degrees — this will work in pretty much any version of Carbide Create
- use the nifty new Circular Array tool which is available in more recent versions — v7 just went stable:
Carbide Create V7
download it from:
Download Carbide Create
(some folks would pause at the quarter or halfway points, clone everything and using horizontal/vertical mirroring — for instances where there are more objects that might make sense — you just have to clean up the duplicates)
