I’ve been using 1mm carbide end mills for several projects but today I broke 2 with the same feeds, speeds and cutting material (brass). I noticed that there was a little play in the router holder:
So if I lift up (slightly) the aluminium router holder it moves up a bit. Also the black plate to which it’s attached moves backwards by the same amount.
I’m wondering if this is normal or do I need to tighten something? The two screws in front in the aluminium holder are tight.
there are two screws in the back of it (you need to disassemblet he thing to get to them) that will go loose if you hit certain “crashes” (it happens to me when my workholding goes loose and the thing goes rotating around)
easy to fix but must be fixed, it will otherwise only get worse, and it causes miscuts
