Being that I am new to CNC and the Shapeoko setup, I am trying to do a monogram of a couple of letters. LFO to be exact. I had no problem with the L and F, but the O is giving me grief. I want to pocket it but leave the center. Right now, it is just pocketing the whole thing. The way its setup in CC makes the center look like a rectangle, so I tried overlaying one but that didn’t work. Any suggestions would be much appreciated!
Sounds as though the O isn’t a double line. What I do is create a DXF or SVG of what I want and import it into CC. This should create the correct orientation of the double line for the project. (If what I think you are describing is correct)
Sometimes it is best to upload the file, so we see exactly what the problem is.
When creating the pocket for the “O” you need to select both the inner and outer lines of the character. The pocket will be between the two lines, if there is enough space for the bit. It appears you only selected the outer line.
