You will want things not to overlap.
For the text see:
https://carbide3d.com/blog/merging-script-fonts-in-carbide-create/
and you’ll need to use Trim Vectors for the rest, and it will probably be necessary to have two separate copies of the script text.
If you have difficulties with this, post the file.
Part of this is Figure-Ground reversal — see:
