Pocketing out an area
As requested on support…
Open/unclosed geometry (indicated by being magenta):
can only be used for Contour toolpaths.
In order to pocket the oval it will need to be combined with the leaves in such a way that a closed region will then be defined.
Probably the easiest way to do this is to first re-create the ovals:
Group and note the dimensions:
Then draw a circle and scale it to those dimensions:
If need be, draw in geometry to determine how much we are off:
then add that dimension:
Draw in geometry to determine how much to inset:
and adjust as needed until one arrives at:
Select the open geometry and put it away on a reference layer and hide it:
One approach here would be to have the leaves stand proud — select them and the surrounding geometry:
and then assign an Advanced V carving:
Draw up the cut and the tool in profile:
and use Boolean intersection to get the cut profile:
so that a rectangle may be drawn to determine the width to offset:
Select the leaves and offset by that dimension:
Apply
Select the inner oval and the offset leaves and subtract the offset:
Select the outer oval and the offset leaves and Boolean Union:
Select this geometry and the text and the outer and do an Advanced V carving:
starting it at the bottom of the previous one.
