When CM is running a program, hitting the Spacebar will invoke the Pause button. This is great, much easier than hunting by mouse.
Once Paused, what should CM do if you hit the Spacebar again? Right now, it invokes the Emergency Stop, i.e., CM drops the connection to the machine, and you have to Initialize to continue.
On the plus side, that gives pretty quick access to Emergency Stop without having to mouse around. But, the best E Stop is one that cuts power, not one in software.
On the minus side, all my experience with ‘Pause’ behavior in other situations is that it acts like a toggle - hitting it a second time should ‘unpause’, whatever that means in that context.
- Do Nothing
- Start
- Stop (same as Yellow Stop button)
- Emergency Stop (same as Red Stop button)
