Possible bug with engrave toolpath
I’m running a job where I run an engrave toolpath then a contour with the same v-bit. When I open the file in CM it registers that bit as 2 different bits. I selected them the same, they even have the same settings, but it acted as if they were not the same bit.
To replicate create an engraving toolpath with a v-bit then a contour toolpath with the same bit and open the file in carbide motion. In my case, that resulted in the bit being shown as needing a bit change between the two toolpaths.
I created a test file to show what’s happening. THere are 3 toolpath groups for 3 different bits. The first is a 1/8" ballnose, the second a 1/4" upcut, the third a 60deg v-bit. When I look at the g-code that’s outputted I can clearly see that after the contour toolpath with the v-bit, there is an additional M6T302 command that indicates a toolchange even though there was already one before the contour toolpath.
test toolpaths.nc (1.6 KB)
test.c2d (52 KB)
I agree that this is a bug, and it has been reported before:
