I have what I think is the latest update of Fusion 360.
The last post I have seen regarding the setup, it looks different than the actual screen.
Example:
There is also a second page called operations. on this page it reads “reorder to minimize tool change” It is blank. I assume this will populate after setting up a project.
Yes that looks correct to me and yes when you generate toolpaths the operations will populate under the operations tab and allow you to change the order, change tool numbers, etc…
