I have a periodic problem with my nomad 3, I presume it is with the power supply or something with the motherboard.
The power supply being on for longer periods, several weeks at a time causes varied output, both in power and in sound coming from the motor. At its worst, like In this video the spindle does not start.
The solution has been to unplug the power supply, and to discharge the capacitors in it by powering on the Nomad while it is not plugged in to the wall.
The power, and the sound of the motor varies greatly, and the sound of the spindle gets stronger as the motor power gets lower.
Anyone notice the same?
I am on 230V if that makes any difference.
I will contact support
