As noted elsewhere I need to swap out my old unsupported Sparkfun controller for the Carbide controller that came with my XXL upgrade. The main issue (IMHO) is the power connector on the controller board.
Board is in an enclosure with a heat sink in between. I’d rather not remove it and there’s no access that I can see to the power pins on board while its in the case.
Looks like I am going to have to build my own. I found one adapter on Digikey that was correct, but min quantity 1000 ($4000). Dear Carbide: please STOP with the proprietary parts, particularly with electronics where the world has moved to open designs!
The constraints are to use barrel connectors like 90% of the available power supplies and to not use a 4 pin wiring configuration that is even more rare. For all its faults the Sparkfun board used a standard 24 barrel connector power supply. I found the one power supply that seems to be compatible and available but it takes two weeks with $10.00 shipping (on top of the $50 cost). I found a handful of adapter cables but they are all wired differently than the Carbide unit. I had Digikey on the phone trying to help me search their massive inventory and the only thing we found was what I mentioned (custom order min. 1000).
Well I bought a different model but essentially yes. I bought a 4 pin mini din solder-on inline (cable) end and a 2.1 mm female barrel end with a meter of 4 wire. I still have the power supply coming over on the boat but the adapter parts will come in about 3-4 days which is about 1-1/2 weeks before the whole supply is due.
