I’m working on a project and accidentally overwrote X0 and Y0.
Is it possible to get the old ones back? Perhaps CM logs?
I, definitely, could use BitZero but not sure if this get me precisely back …
Thanks!
Thanks!
I would use the same method you used to set it the first time.
I don’t think the log gets saved. I think it only logs when the log is open.
Thanks Tod
I’ll use this, but I decided to ask first just in case.
