Pro 5 Base Thickness Dimension
Looking for the dimension from the bottom of the base to the top of the MDF inserts on the hybrid extrusions. See image. Many thanks!
I flattened mine and I have about 2-1/8" left. I didn’t take much off when surfacing.
So I’d guess new ones would be just a touch bigger.
Hope this helps.
:smiley:
Edit: I did put a shim under mine to get a little bit above the T-Track.
So the actual dimension would be what @dnbanko posted.
:poop: Sorry about that.
Mine measures 1.945" to the stock, unsurfaced MDF spoiler board.
