Pro x/y/z limit pinout
Assembled my pro yesterday and I’m encountering a couple of issues. The biggest one being that the device will fail to initialize due to not detecting what I assume is the x limit sensor.
If you have a working pro, can your please snap a photo of the pinout that connects to the board? Photo attached of what my x limit pinout looks like as an example. If you can snap one with all three, that would be great.
Thank you,
Write in to us at support@carbide3d.com and we’ll do our best to work through this with you.
Voltmeter to the rescue, problem solved. Labels on the connectors were incorrect.
Also, I’m sure this is mentioned elsewhere but I’ll restate it anyway. The initialize sequence is Z, X, Y. If things do not go in that order, you likely have the cables connected wrong. Not that I did that. :slight_smile:
