Trying to setup bit setter on Shapeoko Pro XXL but having issues. I followed the procedures in manual section 10.6.
I can’t get the machine to job forward enough to center the bit over the setter. Any ideas?
Disregard. Found the answer in an answer Will responded to in my surfacing post. Manually change Y to 865mm.
If this is a known issue, what isn’t the default travel settings for XXL changed in next software update to help other newbie from having this issue. Just a recommendation. Thanks for help Will.
It would be better to retension the belts so that changing the Y-axis travel dimension isn’t necessary.
