I’ve had my Pro for a bit over a month now and I love it, save for this issue that puzzles me. This costly, crazy thing happens with my machine and I don’t understand what I’m doing wrong. Here is my workflow.
Create design with Vectric Desktop Pro (for compatibility with a buddy that has a different CNC)
Create Gcode
Start Motion, connect
Follow prompts, initialize, use bit setter as part of process
Find and set zeros with BitZero.
Load program in motion, Start program.
Load correct bit with BitSetter
Turn on spindle, double-check that the Z value in Motion makes sense
And then it happens. The machine suddenly acts as if the Z zero is much lower and digs into the board in an ugly fashion as it travels to the initial starting XY point.
So, I pause as quickly as I can
Stop the program.
Machine homes itself
I re-find the zeros with BitZero
Then re-start the program and the machine works great running multiple programs until I cycle the power again.
Please take photos of your Z-axis motor wiring, including the extension connectors including at the controller and send them in to support@carbide3d.com and we will send you replacement connectors which should address this difficulty.
If this isn’t a machine fault, then it might be caused by what you are doing right at the start. Is there any chance you are putting the first tool in (the one you are BitZero-ing with) without being prompted to do that? For example, when you are on the Jog screen?
Thanks for the answer Josh. I’d say that’s not it because it starts working again. It’s random so I doubt it’s program related. At least as far as I know
However, the principle is reasonably simple: don’t change the endmill unless there’s a dialog on the screen that says “change the endmill”… well, whatever the words are on that thing
