Probe / BitSetter Input Pin State Issue
The BitSetter on my machine lights up green when pressed down, but Probe / BitSetter Input Pin State doesn’t change in the Machine Settings Debug tab. How do I debug?
  • Check all the wiring connections (including inside the controller)
  • If you have a BitZero, make sure the input triggers if the magnet touches the base
  • Contact C3D support.
