Found details for the Nomad on probe pinout here; https://docs.carbide3d.com/assembly/touch-probe/
However, if using a 3rd party/DIY probe without the fancy LED (5v) I wanted to confirm if I can use the same pins on the board without issue.
If so, which pins are which? (i.e. not 5v)
Pls & Thx
Nobody?
Well does anyone know if there’s any harm in connecting a multimeter to the pins while it’s running to find the 5v ? Presume it’ll be fine, but also I have no idea how these things work.
WillAdams
(William Adams (Carbide 3D))
May 10, 2019, 7:27pm
3
Contact us at support@carbide3d.com for an annotated board diagram.
mikep
(mikep)
May 10, 2019, 11:17pm
4
Go here: I’ve posted diagrams. You want the one with the huge cap on it towards the top. Has a line drawing below it that shows the probe pins.
Thanks!
I reached out direct and Carbide tech advised I avoid that plug shown in first image due to the 5v.
He mentioned using a Y connector at the pins used for the built in tool probe. Follow wires from tool probe to the board.
For reference; when looking at the board. Left pin/wire is probe signal, right wire/pin is ground.
system
(system)
Closed
June 9, 2019, 11:44pm
6
