I have a Stepeoko with the SparkFun Stepoko board and the Carbide 3D touch probe. The probe LED works correctly (green when not touching the spindle, red when touching) and the probe algorithm appears to work. When running Carbide Motion (v.4) routine, as the z probe reaches the plate and the light goes red, the z continues to move down as if it didn’t get triggered by the contact with ground. So the software works but the signal isn’t read when the grounded probe touches the aluminum block. Any advice? Thanks!
