Problem: VCarve Toolpath for straight lines not showing in Simulation
Hi. New to Carbide Create. Using version 628.
All simulations show just fine except VCarve - with the caveat that text works. Straight lines do not show.
I’ve been trying to put a decorative box around holes using straight lines. A straight line will not show in the simulation for a vbit using VCarve.
Updates to my Surface Pro (Windows 11) for OpenGL have been made. My OpenGL is 4.6.0 Build 30.0.101.1191.
I don’t think it is the OpenGL as I can get text to work in the Simulation.
No doubt I am doing something bone-headed. Suggestions?
Could you post a screen grab or a file?
I can get straight line V carvings using a rounded rectangle:
Hi Will. Very interesting. I can get your example to work too.
So, I am thinking my boneheadedness is that I was using a line instead of something like an elongated box. Is that my issue?
I was erroneously thinking that a simple line could be used.
Thanks for improving my learning curve on this. I believe that is the ticket.
Correct. V carving does not work w/ open geometry, only closed.
