Problem with BitRunner on shapeoko 3 xxl
Hi
I move my shapeoko and i am have a problem with bitrunner. the red light do not come one. I have check the cable and it look like. I know the router good because i plug that info the wall and it work no problem.
How to i test bit running is working or how to do i troubleshoot this problem.
On my SO3 I have had connection problems with the BitRunner v1. Double check your connections at both ends. When you move the switch on top the light should come on. If it does not it is not getting power.
