Problem with Scallop operation and direction change
You can use “comparison” and adjust the tolerance value to see exactly how much stock will be left after finishing. Also your tolerance and smoothing values in the toolpath tab will have an effect.
Adjusting your cut direction and up/down milling can also have an effect.
