I just got my Shapeoko 3 in mail and started to assemble it but didn’t get very far. I had screwed in the leveling feet, and was starting to screw in the waste board and cross straps to the end plates and noticed that it was a little lopsided. So I took everything apart and noticed that 1 of the built in nuts used to secure the screws to the end plates from the wasteboard was the opposite of all of the others even the ones on the other side.
Is it a missing pem nut (threaded insert)?
Hard to tell from the picture.
If you compare it to the matching bracket, - and it is indeed a missing pem nut then you can proceed with your build, using a 5mm nut or you can wait for us to send you an insert.
And whatever it connects to isn’t meant to go under that? I have the smaller machine w/o the straps, hopefully someone with a larger machine can chime in.
No, because with the nut on the top it creates a slant in the waste board and then I cant screw the screws in all the way so the waste board will be loose.
I’m with Craig, I’d counter bore the wasteboard on the bottom to accommodate the nut and be done with it. It will take you 2 seconds with a good drill and proper size bit. The wasteboard will sit flat after that.
But you should still tell CC support so they can makesure manufacturing isn’t an issue on their end also (May save a few more customers)
