I started a new file and am ready to create toolpaths. It’s a simple triangle that I want to make several copies of. With the one triangle I created a tool path. No problem. Copy and pasted to get a second identical image for cutting multiple copies. The first image is all correct, showing outside right toolpath. The second image shows inside left toolpath although the toolpath setting still says outside right. Never had this problem before. As the image shows I inverted the second image to save space when cutting multiple copies. I do this all the time without an issue. If I don’t invert it, I can make multiple copies and the toolpath is correct. What could cause this. Using the latest version of CC7.
Thanks, Art Bodwell[date=2022-09-04 timezone=“America/New_York”]
WillAdams thanks, never thought of that, but I’ll remember it now.
