I have a problem when homing my Shapeoko 4 XL. It was working well just a few hours before it began to happen. It occurs when I initialize with Carbide Motion.
The X-axis moves very weirdly, shakes, goes to the left, then to the right all of this with a lot of noise and is unable to complete the homing process. I tried to check V-wheels and belts but nothing changed . I tried to disassemble the X-motor and launched the initialization and the motor is shaking and making the same noise as when assembled.
Do you have any ideas on what could be the issue ?
When unpluging/pluging I realized that one of the little wires went out of its plastic socket. I now works perfectly.
Thank you very much, it made my day!
Please let us know about this at support@carbide3d.com if you have an SO4/Pro/SO5 Pro (the Micro-Fit connectors require special tools to make up/dismantle properly), or if you need help with the repair of the Molex KK connector on a Shapeoko 3.
