my v-wheel on the zplus is coming into contact with the belt clip on the x axis when homing the machine. My proximity switch on the rear of the zplus is positioned correctly. Any ideas?
Loosen the belt anchor, cant it away from the V endmill — you should be just able to get clearance, then tighten.
ok thanks i’ll try that.
also, just out of curiosity, how do i know if the proximity switches are actually working? is there a way to test them?
pushing the belt clip away from the wheel while tightening gave it just enough clearance. There is hardly any clearance. Thanks
Loosen the bolt and hold clip with pliers while tightening. Without holding torque of tightening screw will move clip into path of v wheel. There is very little clearance.
