I recently purchased the VFD spindle for my shapeoko pro. Is there a spec sheet published for the spindle with RPM, hp, and feed rate numbers?
Feed rates dependent on usage. Speed is reportedly 8,000 - 24000 RPM. Output power is likely ~1HP at 24,000 RPM and ~1/3 HP at 8,000 RPM.
