Question about Carbide Bits
I am just starting to Engrave. I have a plaque I want to do.
The lettering is about .25 inches and .40 for the title. Using the 60 degree vbit and for the larger letters it looks fine, for the smaller letters it looks not well defined. In reading it looks like I can go to 30 degree but have 2 questions.
  1. how do you enter that into Carbide Create toolpath. There is not 30 degree
  2. In looking at the products, there is an engraving kit. (501 and 502). Would that be a better choice?
This will be a hardwood sign.
Thanks in advance
you can add you own custom tools (@WillAdams has a tutorial for that) and there you can specify any angle.
One of the things to look at is some like this: https://www.ebay.com/itm/1-4-Diameter-30-Degree-1-Flute-Solid-Carbide-V-Bit-CNC-Router-Bit-Rogue-USA-G25/254785494727
The old (316) method isn’t compatible with the new (400 and later) method, and unfortunately custom tools from 316 are not directly imported into newer versions.
In the newer version in order to enter a custom tool it is necessary to create a new user library — tools may then be added to that by using the graphical interface.
See:
Note that since the move to curated values in 434, certain entries which were required are now hidden in the data since they are not needed.
For V-angle/feature size see: https://wiki.shapeoko.com/index.php/Endmills#V-bits
Note that the #501 and 502 are intended for PCB engraving — they have a rounded tip which makes them more durable, but not as suited for fine detailing.
