Hello guys, I was wondering… when doing the “Finish Machining Toolpath” with really detailed models like this one:
Do you normally go with the grain, against the grain or using a 45° angle? Thanks.
The last pass should be done w/ the grain, but I’ve found it helpful to do other passes at various angles.
Depending on how the project looks you may need to run the finishing pass more than once. As @WillAdams suggested run the finishing path at different angles to help get rid of fuzzes.
