Question on electrical circuit needed for a Shapeoko 5
I am considering a Shapeoko 5. How many amps does a Shapeoko 5 draw? and how many does the compact router draw?
I have a fein turbo 1 vacuum that draws 9amps.
Can I safely plug in the shapeoko 5, dust collector and compact router on one 15 amp circuit or should I use a 20 amp circuit?
As noted at:
https://carbide3d.com/shapeoko/shapeoko5pro-specs/
Amperage 4A (Machine Only)
The compact router:
should draw ~11 Amps at peak, so a single circuit won’t work.
At a minimum it’s best to have:
  • machine and computer on one circuit
  • vacuum and trim router/spindle on a second
If possible, put the vacuum and trim router on separate circuits for a total of 3.
there I have 2 questions
Basically when in CM I click on MDI then type in
M3s10000 it comes up busy straight away then everything I type into mdi same thing happens busy
I’m hoping that the second problem is related to the
First
When I push round button on vfd the spindle starts and and goes up in speed the display reads 400.0
So I have no clue what that is in rpms the stop button turns it off but the run button does nothing is this because it’s the brand vfd so I shouldn’t be pushing the run button
Really red your help
