I most certainly agree, particularly on the horizontal steps. But the machine marks seem to indicate runout, or maybe a lack of rigidity. I get a similar effect from my table saw, the spacing on the pattern is determined by how fast I feed the plastic through. And because of this phenomenon, I typically prefer to fabricate a temperate, then I use a router and bushing to make a cut that, by my metrics, is a finished product. Otherwise, and is currently the case with the acyclic I am currently getting from the Shapeoko, I need to sand before I polish. I don’t consider sanding HPDE an option, but I also don’t think the demands on finish are as high.
For HDPE, I’ve tried feeds as low as the 20 or so IPM? that CC recommended previously, on up past 100IPM reaching towards that which is suggested by King the manufacture(They suggest 150-250 IPM, 18-20K, determined by machine abilities.), and now the newest Carbide curated Speeds and Feeds (100ipm, 10k). I cannot honestly say that I know what my Carbide router is spinning, but based on the supplied paperwork, dial with more clicks than numbers, I am spinning between 10k and 18k, though I’ve pushed it higher during experimentation. The last pieces I cut were a .05 DOC with a .250 #278-Z, which is closer to the now suggested Carbide DOC of .04. I’ve experimented with DOC’s to .5 of cutter diameter, and I’d venture to guess that is still conservative. The material isn’t very demanding. For reference, I machine this stuff regularly with a quality large router in hand at a max available rpm of 23k, and a small Makita laminate trimmer that spins only at 30K. Feeds are whatever my hands happen to be doing based on coffee level and size of part. Finish is typically always the same, about perfect.
For Acrylic, I’ve used the previous CC suggestions, and the new suggestions from Carbides software and youtube videos. I’ve tried a lot in between, and a little bit more. I think I am currently cutting around 50 ipm, but I’ve cut as low as 10ipm for the sake of experimentation, same approximate 10k-18k range. I’ve kept DOC conservative because I don’t find acrylic as friendly as HPDE.
The I’ve tram’d the machine a few times now using a variety of methods. A laser, 123 blocks, and careful measurement. I believe I’ve gone a bit beyond the provided instructions and most of which I’ve seen on YouTube. My machine measures square, Y-rails are perpendicular to bed and square to one another, X rail is squared to bed, and router is squared to the bed. Cuts a clean spoil board. I’d think if it was a tram issue, the steps would not be persistent about the part, but would be focused on a particular portion, and/or inverted from one another i.e West stepped in, East Stepped out. But to be perfectly honestest, I am new to all of this. I am a diesel mechanic, but I work on all kinds of motors. I check/measure all kinds of things, but I send it to someone that knows what they are doing to machine it.
I haven’t tried this tapping method, I’ll try to search that. As of now, my plan to was to buy another option and measure it against the carbide. Like the variable Makita router. My Makita laminate router(only spins 30k) indicates lash that I cant register. I can feel the Carbides bearing lash with my fingers. I don’t have any indicators, but I am using a Starrett and a cheap dial indicator mounted to a magnetic holder. I have the indicator perpendicular to the mill, riding on the center of the mill. I have the mill inserted beyond the collet. I am taking my measurement as far down as possible, but because I don’t have a blank, this is only about .5".
Mechanics seem good. My eye indicates deflection about the v wheels. I suppose I would describe this as lash between the v-wheel and the steel plate. Are these shimmed, or could this be bearing lash?
As mentioned before, I’ve got no experience with a machine like this. Just sort of learning as I go. For my rigidity comparison, the only thing I have is a hand operated router sitting on a sheet of plastic. If I grab the mill, its more difficult to deflect the weight of the unassisted/out of hand router.
Thanks for the help guys.
