When I import multiple shapes (or letters) at the same time they are grouped. How do I ungroup them?
Obvious keyboard shortcuts don’t work.
Didn’t see it in the manual.
thanks
sorry if this is a silly question…
thanks
When i click away, it deselects everything. Then when i click back on a single shape or letter, it selects the entire group. How do I select a single part of the group? or how do I ungroup?
thanks
Alisha:
The icon Will pointed out changes function - from group to ungroup - depending on whether the elements you are working with are grouped or not. Ungroup to select a single element.
This advice is from a novice user of Carbide Create.
Bill
Click on “Ungroup Vectors”:
Then either click-away to deselect everything, or shift-click on a specific element to remove it from the current selection — shift-clicking on an unselected element will add it to the current selection.
For text you will need to convert it into paths first, see:
https://carbide3d.com/blog/merging-script-fonts-in-carbide-create/
