Radius End Mill for tool in CCPro?
I don’t have Pro as yet. Those that subscribe, is there an option to add radius end mill to the tool library? Essentially a bowl and tray bit.
No, only square end mills, ball mills & Vee Bits. If your bullnose bit has a small radius, enter it as an end mill. If a larger radius, enter it as a ball mill. Your simulation won’t look correct, but in most cases you can imagine the difference and still verify the cut is what you are trying to do.
