I’m still fairly new to machining and still learning the ropes.
I have a straightforward part. I start with a rectanular block. I’d like to cut one of the sides to a subtle radius first. Then, I’d like to drill some holes. I need to do a tool change in between. I had no problem creating the design in F360, but am not sure how to separate the two for the Manufacturing process. I’m not sure what to search for as I’m not sure what this process is called in F360.
