Can anyone help explain what i am doing wrong? I am trying to make a raised letter sign with and i can’t get the flourish or EST 2022 to carve properly.
You will need to either use a smaller tool, or an Advanced V carving toolpath with pocket clearing (if you have a BitSetter).
Hi Will,
Doing the advanced vcarve leaves areas that look like they are not cut. Is this still a tool issue? I’m using 1/16" clearing bit with a 30 degree Vbit.
Please post the file.
Knotty Wood V-Carve.c2d (448 KB)
Here is the file
How did you define the 30 degree engraving tool?
The design looks as expected using a 30 degree tool defined as:
Will,
I actually didnt define the tool. I found a library that someone made with all the Sainsmart bits. The bits i have are Sainsmart mostly, with some Amana.
This is how they defined the Sainsmart 30 degree bit:
