It depends on the geometry of the tool. If it’s a center cutting tool, you can ramp at any angle.
If it’s a solid center, side cutting tool, you don’t want to ramp or plunge at all.
If it’s an inserted tool, or a tool with relief in the center, the max ramp angle is determined by the cutting edges on the tool…
For aluminum, I usually use 2-3°
Appreciate the advice as always! For a center cutting tool does that generally mean drill bits and engraving tools?
I’m not really knowledgeable on end mills, but typically I use 0 flute upcut end mills and make very shallow DOC. Those seem to cut down and sideways at the same time.
How does ramping angle change in something like hardwood compared to aluminum? Do you generally take a larger angle?
No ramping = direct plunge and then sideways movement.
Ramping = diagonal cut easing into the material.
Aren’t ALL ramping angles superior to direct plunging? Even highly aggressive ones?
I should take 20% ramping over plunging right? It’s seems to be generally superior in all ways especially if the cut time is the same. At the moment I’m not cutting anything that needs to be precise, just basic shapes that have to look symmetrical to the eye.
Here’s what ChatGPT says
If production speed is your primary concern and you need to choose between a higher ramp angle (10-20%) and no ramping at all, it’s important to consider the trade-offs involved:
Higher Ramp Angle (10-20%):
Pros:
Faster material removal rate compared to no ramping at all.
Reduced cycle time due to more aggressive cutting action.
Cons:
Increased stress on the cutting tool, potentially leading to shorter tool life.
Greater likelihood of tool breakage or chipping, which can halt production and incur tool replacement costs.
Higher risk of vibration and chatter, which can affect surface finish and machining accuracy.
No Ramping at All:
Pros:
Reduced stress on the cutting tool, potentially prolonging tool life.
Lower risk of tool breakage or chipping, leading to fewer interruptions in production.
Improved surface finish and machining accuracy compared to using a higher ramp angle.
Cons:
Slower material removal rate compared to using a higher ramp angle.
Longer cycle time due to more conservative cutting action.
It claims plunging with no ramp reduces stress on the cutting tool compared to an aggressive ramp. Is that true or is AI making things up and sabotaging me again
Seems to be a non-issue now that I set my retract height at 2mm.
It did some testing and the reason it was taking so long was my retract height was too high. It was doing a suuuper slow downward spiral. The time difference now is barely anything.
