Rapid going out of tile in tiling
Hi,
When I create my nc files in a job that requires tiling the software creates a path that goes out of the tile. What did I do wrong? I can’t do this job because tile 2 would require the machine to go further then is possible…
Printscreens of the rapids:
Tile 1:
Tile 2:
Paths:
Does anybody has an idea?
Thanks,
Dimi
In design, can you see possible nodes outside your work area? Not that you placed anything there on purpose, however is there a possible node there that needs to be deleted?
One on the top right, and two below. Click on those and delete. Ungroup in necessary.
Please send this file in to support@carbide3d.com and we will try to look into it.
Thanks for your response Michael! That was my first thought too. But no, if I select everything I get the size I expected. Nothing outside the stock size.
I just send an e-mail. Thanks for looking in to this.
