Rapid Position to Tool Bit Change Location
I often use the Rapid Position feature to get the spindle quickly from one location to another. What I would love to see is a button on the right side of the Rapid Position screen with the rest of the green buttons that is
RAPID TO BIT CHANGE
Being in production mode while in the shop, I will often rapid position to SE, but that is just a little tight to change a bit.
There is a button on the run screen that says “tool change.” If you press that button, the spindle moves to the traditional tool change location.
Ah!! Perfect! I have not noticed that to be aware of what it does. Thank you :smile:
