Rapid travis feed rate
Hi Everyone,
I would like to reduce the rapid feed rate settings on my SO3. How do I make the settings to lower the rapids ?
Thanks in advance !
Brian
you can modify the “max (feed) rate” settings for X, Y or Z axis by updating the following parameters:
$110 (x max rate, mm/min)
$111 (y max rate, mm/min)
$112 (z max rate, mm/min)
Sorry, I do not understand how to do this or what numbers to add.
You can use the 'MDI" tab in CM to send commands to the controller, by typing, for example,
$110=500
And hitting send, this will update the parameter 110 to 500mm/min max feedrate setting. Similarly, modifying $111 will limit Y max feedrate.
If you are not comfortable with this, it’s probably best to not do it. At any time you can resend machine configuration to restore factory settings.
Got it. Thanks for the help !
