Raspberry Pi 5 & Carbide Motion
Has anyone here been able to get Carbide Motion to work with their RPi5? I have it installed but it won’t open up. Also, @robgrz was saying that
I’m new to the rpi ecosystem and could use guidance if anyone has figured this out.
Yes, I’ve been using an RPi 5 for my Carbide Motion with no issues. It appears the issue with the OS was fixed sometime in the bookwork release, which is required for the RPi 5. Make sure you are using 32-bit, as I don’t believe the 64-bit version works with Carbide Motion for RPi.
thanks for calling out the 32-bit OS dependency, @myklhn ! Per usual, devil is in the basic details.
