I had a friend approach me and asked if i could carve a image of "Rat Fink " from old drag racers. I searched and found images , but nothing that I could convert to SVG , The only one I could convert and do a advanced V carve would have run for 8hr for a very small image. Any one have any ideas or helpful info so i can help my friend out. Thank You.
Here is a simple clean SVG.
https://www.deviantart.com/johnny-sputnik/art/Ratfink-103556586
- Begin by performing a Google search for the image you desire. For instance, you can use the search term “Rat Fink Art.” Once the search results appear, click on the “Images” tab.
- In the search results, click on the “Tools” option, then select “Image size” and choose “Large.” for the type of image select “Line Drawing” to refine your search.
- After refining your search, browse through the results and left-click on your preferred image. When you do this, a sidebar will open on the right side of your screen, displaying information about the image, including its size. Hover your mouse over the image to see its size.
- From the Right Sidebar image. Right-click on it and select “Open Image in New Tab.” This action will open the image in a new tab within your browser.
- Navigate to the newly opened tab containing the image. Right-click on the image again, but select “Save Image” to save it to your computer.
- Next, open a new tab in your browser.
- Go to the website https://picsvg.com/.
- Upload the image you previously selected. On this website, you’ll have several options to adjust the image according to your preferences.
- Once you are satisfied with the adjustments, click the “Download SVG” button to obtain your customized image in SVG format.
