There is a Cam Clamp design at:
https://carbide3d.com/3d-print/cam-clamp/
which is available as an STL, but cutting thus would require Carbide Create Pro, which this 2.5D design should not need.
Opening the file we get:
so create a new file of suitable dimensions:
and import the STL:
which imports as expected:
which can then have the outline traced:
at various heights:
which then need to have multiple elements deleted:
and if desired, re-created where not round enough:
and where necessary, create flat geometry which is equal so as to determine the thickness:
Then assign toolpaths:
and if a tool won’t fit, use a smaller tool:
and add offset geometry:
Then use a Contour toolpath to finish cutting after assigning tabs:
and add additional toolpaths as desired… which previews as:
Attached as a v8 file:
carbide3d_cam_clamp.c2d (1.3 MB)
