As requested on support…
Given a file which isn’t quite what one wants:
one can put this on a template layer, lock it, and re-draw it.
Select everything, create a new layer, move it to that layer, then lock that layer:
Draw in geometry snapping it to the nodes and in Node Edit mode adjust things:
until things line up:
Draw in geometry for the pockets:
and use Trim Vectors:
and then join them:
If need be, duplicate the outer geometry and get the intersection:
