I want to finish a job that disconnected twice on me near the end of a 3 hour run. I have 6 hours in this thing and I don’t want to cut any more air. I have searched some, but I cant seem to find a decent tutorial on this. I just want to get the project off the table so I can troubleshoot my problem…
pauxier, not too sure if this will help. I’ve had the same problem while etching a USMC emblem on acrylic. It did this a couple of times before I thought I knew the problem. What I did was go back into the design and save the tool paths again. It was a detailed file and what happened was I had inadvertently saved the g-code and closed the file before it finished saving the tool paths which took a real long time. Hope this helped you out.
