Recommendation on ball nose / cove bits
One of the first cheap set of bits I bought was this set of bits from Amazon at $12 -
Yakamoz 6Pcs 1/4" Shank Round Nose Groove Router Bit Set https://smile.amazon.com/dp/B07ZNHB4ZN/ref=cm_sw_r_cp_api_glt_fabc_3GFCN5GCBDCTYZ6M2PH1?_encoding=UTF8&psc=1
The challenge is that this yellow covering peels and burns with the cut, which impacts the wood, and I have become very unhappy with them.
I want a variety of ball nose bits for juice grooves and other items. Hoping someone can suggest a cheap alternative that they are happy with.
FYI - I could see that I could buy individual whiteside bits for $20-$30 a piece, but was hoping someone had good experience with a cheaper alternative
If the paint is coming off that easy I wonder if you could just soak the bits in a paint remover (acetone) and use a wooden tonged depressor/chop stick to scrap it off . A little time consuming if you want to stay cheap.
