Can someone recommend an 8th inch end mill bit with 1/4 inch shank that can cut out 1inch wood material. Most of the time I’m cutting ¾ inch and the bit I have does fine for that but I need something that will cut the 1 in material. Any recommendations would be nice .
Why would you want a 1/4" shank which will just increase the expense of the endmill?
I’ve had good luck with:
